router console dial up remote
Jul 13th, 2009
Looking for help in configuring two c2811 routers, one with modem card installed and one external/aux to support secure remote dial in to console for remote management. Thanks
slmansfield Tue, 07/14/2009 - 10:53
My strong recommendation is to purchase another external modem and connect each modem to the console port of each router for remote management of the router.
The two options you are contemplating don't provide console access in the event the router cannot load its configuration. If the router is sitting at the ROMMON prompt or rebooting itself continously you will not have remote access to its console to firefight.
Here is the URL to configure a US Robotics modem for the console port of a router.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a00800941c9.shtml
