Downgrading from 5.0.148 to 4.2.205
Answered Question
Jul 13th, 2009
I was told that version 5.0 code for the 4402 was not good to run and unfortunately that was the code that came with the new WLC I am installing ... so I want to downgrade to 4.2.205, is there any thing I should know about doing this? This is for a new install so the WLC is fresh out of the box and no APs have joined it.
Thanks!!!
Correct Answer by Lucien Avramov about 7 years 9 months ago
As it's a new install you can go ahead and downgrade, you may then need to reconfigure the ip addressing over again on the 4.2 code as the XML version of the running config may be different.
Overall Rating: 5 (1 ratings)
Correct Answer
Lucien Avramov Mon, 07/13/2009 - 10:53
  • Red, 2250 points or more
Leo Laohoo Mon, 07/13/2009 - 16:22
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Try the 6.0.182.0.
Lucien Avramov Mon, 07/13/2009 - 16:28
4.2 is much more stable, I wouldnt recommend 6.0 yet.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
