Show Supervisor Backplane Packets Per Second
Jul 13th, 2009
I am looking for the show command that will show the total packets per second going through the switch. I thought I had the command at one point but am having troubles finding it. Every time I look for back plane utilization, all I can find is the CPU.
Overall Rating: 4 (1 ratings)
Collin Clark Mon, 07/13/2009 - 11:26
I don't think I've ever seen pps, but here might be a couple of helpful commands;
<font size="2"></p><p>6503-1#show platform hardware capacity ?</p><p>  acl         Show QoS/Security ACL capacity</p><p>  cpu         Show CPU resources capacity</p><p>  eobc        Show EOBC resources capacity</p><p>  fabric      Show Switch Fabric resources capacity</p><p>  flash       Show Flash/NVRAM resources capacity</p><p>  forwarding  Show forwarding engine capacity</p><p>  ibc         show IBC resources</p><p>  interface   Show Interface resources capacity</p><p>  monitor     Show SPAN resources capacity</p><p>  multicast   Show L3 and LTL Multicast resources</p><p>  netflow     Show Netflow capacity</p><p>  pfc         Show PFC resources capacity</p><p>  power       Show Power resources capacity</p><p>  qos         Show QoS resources capacity</p><p>  rate-limit  Show CPU Rate Limiters capacity</p><p>  system      Show System resources capacity</p><p>  vlan        Show VLAN resources capacity</p><p>  |           Output modifiers</p><p>  <cr></p><p></p><p>6503-1#show catalyst6000 ?</p><p>  all                    show all Catalyst 6000 information</p><p>  chassis-mac-addresses  chassis MAC address range</p><p>  switching-clock        switching-clock failure recovery mode</p><p>  traffic-meter          current and peak traffic meter reading</p><p>  |                      Output modifiers</p><p>  <cr></p><p></p><p>6503-1#show fabric ?</p><p>  active            crossbar fabric linecard active and backup info</p><p>  channel-counters  fabric channel counters</p><p>  clear-block       clear-block congestion control for fabric channels</p><p>  drop              drop counters for different queues in fabric   </p><p>  errors            fabric port errors</p><p>  status            status of crossbar fabric</p><p>  switching-mode    crossbar fabric and system switching modes</p><p>  utilization       fabric port utilization percentage</p><p>  |                 Output modifiers</p><p>  <cr></p><p>  </font>
