UCM 6.0 LDAP integration
Jul 13th, 2009
I am about to integrate my ldap to callmanager. what will happen if i created a account localy in callmanager identical to a ldap account. after the installation.?
Jaime Valencia Mon, 07/13/2009 - 11:20
  • Cisco Employee,
  • Hall of Fame,
    2011
If the user ID you defined in local CUCM matches the parameter you set as LDAP user ID with an exact match it will just be updated with the info from LDAP, otherwise it will be marked as inactive and will be deleted when purge mechanism runs
java
if this helps, please rate
