Auto attendant not answering
Jul 13th, 2009
Hi All,
We have a SPA9000 with a SPA400 and a SPA962 and three SPA922's. We are using an ITSP on line two and are trying to configure the auto attendant to pick up after twenty seconds. The inbound call rings and after twenty seconds the call is cut off before transferring to the auto attendant. We set up the LVS with the wizard 2.1.0.0. All firmware is version 6.1.5. Any ideas? thanks for any help.
George.
Patrick Born Mon, 07/13/2009 - 14:34
  • Cisco Employee,
Hi George,
Could it be that your ITSP is cutting off the call after ~20 seconds?
Consider enabling debugging on the SPA9000 in order to determine what the SPA9000 believes to be transpiring: https://www.myciscocommunity.com/docs/DOC-3032
Please send the debug log and the SPA9000's config to me at paborn at Cisco.com for analysis if you need additional help: https://www.myciscocommunity.com/docs/DOC-3027
Patrick
