Correct boot system slot0 syntax
Jul 13th, 2009
We have a 4510 with two supervisors V modules, both with a memory card. In order to boot off that card, is the syntax:
"boot system slot0:xxx"
or is it
"boot system flash slot0:xxx"
thanks
Overall Rating: 5 (1 ratings)
jimmyc_2 Mon, 07/13/2009 - 12:57
Hi Collin,
Are you sure its "disk0" and not "slot0" on a 4510 with IOS? Either way, you have to include the word "flash" .
thanks
Collin Clark Mon, 07/13/2009 - 13:03
A dir /all will tell you the exact file system. I have not seen 'slot' in a while, most now use disk (I believe it's dependent of the platform).
jimmyc_2 Tue, 07/14/2009 - 06:29
Hi Collin,
The dir /all only returns the bootflash files, nothing in the slot0.
dir disk returns "unrecognized command", while dir slot0: returns the files on the memory card.
The document was only valid for 4500 using CAT OS, and we are using IOS.
But I think you've answered the major question, which is that I have to include "flash" in the boot system statement.
thanks
jimmyc_2 Wed, 07/15/2009 - 04:20
Hi Collin,
I used the command line "boot system flash slot0:xxxx.bin" and everything came up nominally. thanks for the help.
