Upgrade from CUCMBE to CUCM possible?
Answered Question
Jul 13th, 2009
Does anyone know if its possible to upgrade from CUCMBE to CUCM (running on a 7828), is it possible to transfer DLU's from CUCMBE (7828) to CUCM (7825) if the CUCMBE is being traded in, and if there's a tool like DMA to pull the configuration off the CUCMBE and onto the CUCM? Thank you in advance!
Correct Answer by Jonathan Schulenberg about 7 years 9 months ago
The MCS7828 can be reused when moving to a standard UCM cluster. See footnote three on the restriction (namely UCM 7.0 only).
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
You cannot however migrate the database over. The schema on UCMBE includes Unity Connections data and other customizations to allow them to play together. You will need to configure a new cluster.
This is documented here for reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/install/7_1_2/cmins712.html#wp486077
My recommendation would be purchase a second MCS7825 (or 7835 depending on your requirements) and configure that as your first node. You can then migrate things to it and add the 7828 as a secondary node - after a fresh install - once you are up and running.
Note you would also need to buy an appropriately sized server for Unity Connections.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Mon, 07/13/2009 - 16:05
  • Cisco Designated VIP,
    2017 IP Telephony
bmcghee Tue, 07/14/2009 - 12:49
thank you, I took a cucmbe session today and they said the same thing cucmbe 7.x can be upgraded to run cucm 7.x and the dlu's can be transferred as well..
thank for the help...
