catos password change via snmp
Jul 13th, 2009
  • Purple, 4500 points or more
Anyone know how to change a catos device password , telnet or enablepass via snmp if you know the community strings. Have been unable to find anything on the website and don't want to have to go thru the manual recovery process. Any webpages I can look at ?
Lucien Avramov Mon, 07/13/2009 - 19:09
  • Red, 2250 points or more
Basically you can only do the following :
-Download the router config using SNMP
-Change the password on the config file
-Upload the new router config to the router from the tftp server
-Copy the changes to NVRAM
To download / upload the router config :
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008009463e.shtml
To save the changes to NVRAM:
Snmpset -c rw-string #.#.#.# .1.3.6.1.4.1.9.2.1.54.0 integer 1
where:
the rw-string is the router read-write snmp community string AND #.#.#.# the ip address
glen.grant Tue, 07/14/2009 - 03:11
This appears to be for a IOS box .The issue is with catos boxes running 7.X version software. Seems strange there isn't a way to change things via snmp like the passwords .
glen.grant Tue, 07/14/2009 - 09:11
May have found a solution. I found a box that I know the passwords are correct and copied and pasted the "set password and set enablepass lines with the password strings into a file with beginning and end statements for a unix file and then you can config net the file with just the 2 statements and that will change the password without having to know the old password.
