How to force guest network to authenticate
Jul 13th, 2009
Greetings - using ap1230 series. I have several vlans. one vlan that goes right to our company network for RF guns using WPA that connects to our enterprise. Another vlan I have is DSL and is VLANNED accordingly which I allow an open means of wireless. I want to be able to provide soem password of sorts and provided it only to a few users so when they conenct to that network a prompt or some means of authentication is presented to the user trying to use it. Not only that I would need to change this password every now and then so it keeps the users honest. any hints or tips?
planzone Tue, 07/14/2009 - 04:14
Perhaps I should of mentioned this.
How can i do it with spending almost next to nothing.:)
Anyhow There is a ACS appliance in the enterprise but not at my location (at about 100 miles away) we are connected via MPLS. But I know very little about the ACS.
paulpoon Thu, 07/16/2009 - 10:51
Are you using controller based or the autonomous ones. If you have controllers, then its really easy. Just set the security policy on that WLAN to web-auth. Then set up the web login page and create accounts via the WLC.
Trending Topics - Security & Network
