The is-is issue
Answered Question
Jul 13th, 2009
Hi,dear all!
when I configurate the is-is,it show the error msg below:
one port is:%CLNS-3-BADPACKET: ISIS: LAN L2 hello, bad circuit type 0 from ca03.0b20.001c (FastEthernet1/1)
and the other port is:%CLNS-3-BADPACKET: ISIS: L2 CSNP, packet length 0 less than header length 33 from ca04.0b20.001d (FastEthernet1/0)
can anyone help me,and are there have doc to reference?
TKS...
Correct Answer by Giuseppe Larosa about 7 years 9 months ago
Hello Bo,
it looks like one of the two routers is not running IS-IS correctly.
May you post the platform models and the IOS images you are using?
And eventually the parts of your configuration involved: interface config is-is process config of both nodes
Hope to help
Giuseppe
Overall Rating: 3 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 07/14/2009 - 03:16
  • Hall of Fame,
    Founding Member
Hello Bo,
Hope to help
Giuseppe
huangpo2005 Wed, 07/15/2009 - 17:51
Hi,Giuseppe!thanks your advice very much.i think you are right!
But i'm sorry,when i reset the dymimips and cofigurate the lab again.it's ok!and i haven't save the config.
So if i have any other issue,i will ask you!
