Warning message
T37 onramp on 28XX
Jul 13th, 2009
Hi!
I've configured T37 on-ramp on an 2811 with ios 12.4.15T8 and all works fine.
with long faxes it took up to 1700 sec (e.g with 20 pages) to receive a fax.
Is it possible to speed up the transfer?
Here's the config:
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 10.10.10.5 port 25
mta send subject "Cisco-powered Fax System"
mta send postmaster [email protected]
mta send mail-from hostname 12900.scanfax01.mtelco.com
mta send mail-from username $s$
application
service app_faxmail_onramp flash:app_faxmail_onramp.2.0.1.3.tcl
dial-peer voice 40 pots
description ***** fuer FAXtoMAIL*****
incoming called-number 2600[34]T
direct-inward-dial
dial-peer voice 41 mmoip
description ***** fuer FAXtoMAIL zum SMTP *****
service fax_on_vfc_onramp_app out-bound
max-conn 5
destination-pattern 26003
information-type fax
session target mailto:[email protected]
dial-peer voice 42 mmoip
max-conn 5
destination-pattern 26004
nreyesvgkn Mon, 07/27/2009 - 08:35
Hi Martin1,
Thanks for this document is really helpfull.
But I have some questions if you don't mind.
I'm trying to do the same but I don't know how to configure my email server, actually I have a dummy question, do I need an Unity server or CUE?, I think that no, I have one but I'm not using on this lab. The question about the email server is because I'm using a free software that I download from the web, but after this lab I need to use the corpotare server, so, my question is, what are the configs that I need to do in the email server? do I have to do something special? or just create a mailbox and that it?
Thanks in advance for your support, and sorry about my english.
Regards, Saludos
Nelson
