How to get second dial tone
Answered Question
Jul 14th, 2009
Hi all,
I have a problem. When customer dial "8", it will access the voice gateway. It also delete replace "8" by "20" sent to voice gateway. The problem is customer can't get dial tone when dialing '8'.
dial-peer voice 1 pots
trunkgroup PABX
description To HK Local Extension
destination-pattern 6..
forward-digits all
dial-peer voice 2 pots
trunkgroup PABX
description To HK CO Line
destination-pattern 9T
forward-digits all
dial-peer voice 101 voip
description To SZ Local Extension
destination-pattern 20[1-6]...
session target ipv4:10.1.1.1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 102 voip
description To SZ CO Line
destination-pattern 2069T
no vad
dial-peer voice 103 voip
description To SZ Reception
destination-pattern 200
no vad
Leung Che Man
Correct Answer by CHRIS CHARLEBOIS about 7 years 7 months ago
The secondary dialtone is usually provided by the serving switch, which is this case would be the PABX. How is the PABX routing the call? Usually, the PABX will collect all the digits before sending the call out a trunk. If that's the case, the PABX is still holding the call when the caller should be hearing the secondary dialtone.
Correct Answer by gogasca about 7 years 7 months ago
hi sir,
unless call comes from dial-peer pots without direct-inward dial and u dial 8 from an external system yes, otherwise we need CME, to provide it
Overall Rating: 4 (2 ratings)
gogasca Tue, 07/14/2009 - 00:06
Dial tone will be provided with CUCM or CME or UC500
or by going offhook if u dont have 3 above GW cannot provide dialtone by entering a digit
cm6043 Tue, 07/14/2009 - 00:12
Hi qoqasca,
Is there any alternative to get the second dial tone when pressing '8'
Thanks for your help
Leung Che Man
Correct Answer
gogasca Tue, 07/14/2009 - 00:14
hi sir,
cm6043 Tue, 07/14/2009 - 00:24
Hi qoqasca,
The following is my VOIP connection. is it possible to get second dial tone in the customer ?
customer --- pabx ---- router HK---- ip --- router SZ --- pabx --- customer
Leung Che Man
Correct Answer
CHRIS CHARLEBOIS Tue, 07/14/2009 - 08:24
