Command to clear the bgp vrf table.
Answered Question
Jul 14th, 2009
I want to clear the bgp table on this vrf. Here is how it looks like :-
address-family ipv4 vrf mj
redistribute connected
neighbor 12.12.12.12 remote-as 1111
neighbor 12.12.12.12 activate
neighbor 12.12.12.12 send-community
neighbor 12.12.12.12 as-override
neighbor 12.12.12.12 soft-reconfiguration inbound
neighbor 12.12.12.12 route-map customer in
neighbor 12.12.12.12 route-map vpn-routes out
neighbor 12.12.12.12 maximum-prefix 1000
neighbor 13.13.13.13 remote-as 65222
neighbor 13.13.13.13 activate
neighbor 13.13.13.13 send-community
neighbor 13.13.13.13 remove-private-as
neighbor 13.13.13.13 soft-reconfiguration inbound
neighbor 13.13.13.13 route-map a-in in
neighbor 13.13.13.13 route-map a-out out
neighbor 13.13.13.13 maximum-prefix 1000
no auto-summary
no synchronization
exit-address-family
I would like to confirm that the command to clear this vrf is whereby the ASN is 1110 :-
clear ip bgp vrf mj ipv4 unicast 1110 soft.
Pls advice,
InternetB.
Correct Answer by shivlu jain about 7 years 7 months ago
Yes you are right.
regards
shivlu jain
Overall Rating: 5 (2 ratings)
InternetB Tue, 07/14/2009 - 00:41
Hi Shivlu,
To confirm, since my ASN is 1110, the 200 should be replaced with my ASN number of 1110 right ?
Thank you,
InternetB.
