problem phone 7961
Jul 14th, 2009
hi guys,
i have a problem with phone 7961.
i have a cluster Call manager 6.1 ( publisher and subscriber)
the phone take the DN 175 , and i can't change this DN, i have chek in the route plan reportand i don't see 175, i have deleted the phone , reset the phone , i have regeted the phone manually but without any result.
is this a bug, i have this problem in 2 sites ( first cluster 6.0 and the second cluster 6.1).
please help
Jaime Valencia Tue, 07/14/2009 - 07:01
  • Cisco Employee,
  • Hall of Fame,
    2011
I would suspect in 1st place of DB replication issues, if that's ok then you might have change notification issues.
java
if this helps, please rate
bsaid1977 Tue, 07/14/2009 - 07:32
hi java,
what do you mean by that ?
how i can change notification issues ?
