https probe doesn't work, A2(1.5) - bug verification
Jul 14th, 2009
Hello guys,
I have upgrade to A2(1.5) and in configuration is used https probe. In previous version A1(5a) it works correct. In new version (A2(1.5)) it does't work.
Symptoms are similar for bug ID CSCsy01240. But certificate is valid (It was change last week). The https probe with old sw works, with new doesn't. I found this issue in the release notes for A2(1.5).
My question is:
- Exists any workaround for this issue? maybe new A2(1.6) release in the near future?
- Upgrade to A2(2.0) can be helpful? Is this version safe for production? (I found only A2(1.5) released as safe harbor)
thanks for any update.
