Copy a capture from ASA with context
Answered Question
Jul 14th, 2009
  • Bronze, 100 points or more
I'm trying to copy an capture I've done in an ASA with multiple contexts.
The problem is that inside a context I don't have the command "copy capture:"
The only options for copy command inside a context are "copy running tftp" and "copy startup tftp"
Correct Answer by robertson.michael about 7 years 8 months ago
Hi Guilherme,
To copy a capture in multiple context mode, you use the 'copy capture' command from the system context and specify the context where the capture is contained. For example:
copy capture:context1/cap1 tftp://10.1.1.1/cap1
You can also download it directly from a browser by navigating to:
https:///capture/cap1/pcap
Here is the command reference for 'copy capture':
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/c4.html#wp2123161
Hope that helps.
-Mike
Overall Rating: 5 (1 ratings)
Correct Answer
robertson.michael Tue, 07/14/2009 - 05:46
  • Silver, 250 points or more
Hi Guilherme,
Hope that helps.
-Mike
