Cisco T.37 offramp isn't working properly
pavelsh_ucs
Hello.
I've a problem with offramp faxing.
Problems are:
1. Multi-page faxes does not send. Send only first page ... and all.
2. Sometime faxing ends with error %LAPP_OFF-6-LAPP_OFF_CAUSE_ABNORMAL: Call aborted (cause = 0x1F). One test mail was sent 2 times without this error and 1 time with this error.
sh ver
munich#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 15:13 by prod_rel_team
I'm using this very fresh software because old software doesn't work with faxes at all!
fax receive called-subscriber $d$
fax send max-speed 4800
fax send transmitting-subscriber $s$
fax send left-header $a$
fax send center-header $s$
fax send right-header $t$
fax interface-type fax-mail
mta send subject Incoming Fax to Munich Office Received
mta send postmaster postmaster@1.com
mta send mail-from hostname munichoffice.1.com
mta receive aliases 1.com
mta receive aliases fax.1.com
mta receive maximum-recipients 10
mta receive generate mdn
mta receive generate permanent-error
application
service fax_offramp flash:app_faxmail_offramp.2.0.1.1.tcl
dial-peer voice 400 mmoip
description off-ramp inbound SMTP
service fax_offramp
information-type fax
incoming called-number 0T
dsn delayed
dsn success
dsn failure
irisrios
Level 6
Level 6
No action in needed for “LAPP_OFF-6-LAPP_OFF_CAUSE_ABNORMAL”.
