IDSM-2 error
Jul 14th, 2009
Received follow error after service module was restarted:
From diagnostics event -
07/13 13:08:10.573 E [2] komodo_plus_lb_pc_port[2/7]: check_ether_packet failed (err-code 43)
From sh log -
Jul 13 13:04:34: SP: The PC in slot 2 is shutting down. Please wait ...
Jul 13 13:05:04: SP: PC shutdown completed for module 2
Jul 13 13:05:14: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Reset)
Jul 13 13:08:09: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimal Diagnostics..
.Jul 13 13:08:11: %HA_EM-6-LOG: tmpsys:/eem_policy/Mandatory.go_bootup.tcl: GOLD
EEM TCL policy for boot up diagnostic
Jul 13 13:08:11: %DIAG-SP-3-MAJOR: Module 2: Online Diagnostics detected a Major
Error. Please use 'show diagnostic result <target>' to see test results.
Jul 13 13:08:11: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 2: TestPCLoopback fai
led on port(s) 3-4
Jul 13 13:08:11: %OIR-SP-3-LC_FAILURE: Module 2 has Major online diagnostic fail
ure, Card will be powered reset to re-run diagnostic. Please check sup-bootflash
diaginfo file for previous detailed diagnostic resu
Jul 13 13:08:12: %OIR-SP-3-PWRCYCLE: Card in module 2, is being power-cycled off
(Diagnostic Failure)
Jul 13 13:08:12: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Diagn
ostic Failure)
Jul 13 13:11:38: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimal Diagnostics..
.Jul 13 13:11:40: %HA_EM-6-LOG: tmpsys:/eem_policy/Mandatory.go_bootup.tcl: GOLD
Jul 13 13:11:40: %DIAG-SP-3-MAJOR: Module 2: Online Diagnostics detected a Major
Jul 13 13:11:40: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 2: TestPCLoopback fai
led on port(s) 3-4
rhermes Tue, 07/14/2009 - 07:18
Looks like your IDSM is sick. I'd open a TAC case to get it RMA'ed.
Farrukh Haroon Thu, 07/16/2009 - 00:00
Try removing it from the chassis once and then reinsert.
If that does not work, and you cant re-image the module by any menas, go for RMA, as mentioned by the first responder.
Farrukh
mkelly26 Thu, 07/16/2009 - 00:51
Reseat was my first option as we couldn't access the module. Temporarily indicates good condition but then fails.
Replacement module on route.
