Warning message
EZVPN Server on Dual WAN Interfaces
Jul 14th, 2009
I've configure EasyVPN on both of my WAN interfaces. The problem I'm having is that the traffic is leaving via xxx.xxx.xxx.60 and not on the interface that the Remote site connects to.
What can I do to get the traffic to leave via the interface on which the remote side connects to?
ip cef
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group ezvpn-spoke-pta
key *****vpn-key*****
acl 106
crypto isakmp client configuration group ezvpn-spoke-pta-backup
acl 106
crypto isakmp profile sdm-ike-profile-1
match identity group ezvpn-spoke-pta
isakmp authorization list sdm_vpn_group_ml_3
client configuration address respond
keepalive 60 retry 2
virtual-template 1
crypto isakmp profile sdm-ike-profile-2
isakmp authorization list sdm_vpn_group_ml_4
virtual-template 2
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
crypto ipsec profile SDM_Profile2
set transform-set ESP-3DES-SHA1
set isakmp-profile sdm-ike-profile-2
interface Null0
no ip unreachables
interface FastEthernet0/0
description Inside Network$ETH-LAN$$FW_INSIDE$
ip address xxx.xxx.0.1 255.255.255.0
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
ip policy route-map RouteMapPBR
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1.310
encapsulation dot1Q 310
ip address xxx.xxx.xxx.227 255.255.255.248
ip access-group 101 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip inspect SDM_LOW in
ip inspect SDM_LOW out
ip nat outside
snmp trap ip verify drop-rate
no cdp enable
interface FastEthernet0/1.320
encapsulation dot1Q 320
ip address xxx.xxx.xxx.60 255.255.255.248
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
no cdp enable
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet0/1.320
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Virtual-Template2 type tunnel
ip unnumbered FastEthernet0/1.310
tunnel protection ipsec profile SDM_Profile2
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.225 track 310
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.57 track 320
ip flow-cache entries 4000
ip flow-cache timeout inactive 100
ip nat inside source route-map Nat320 interface FastEthernet0/1.320 overload
ip nat inside source route-map Nat310 interface FastEthernet0/1.310 overload
access-list 106 remark SDM_ACL Category=4
access-list 106 permit ip xxx.xxx.0.0 0.0.255.255 any
Todd Pula Tue, 07/14/2009 - 10:26
  • Silver, 250 points or more
What is the overall requirement of your design? Are you looking to use the FastEthernet0/1.310 path as the primary and the FastEthernet0/1.320 for failover? If this is the case, you can track the default route to .225 and use a floating static route for .57 with a higher AD.
johanhanekom Tue, 07/14/2009 - 23:52
That's correct, FE0/1.310 as the primary path and FE0/1.320 as the fail over path.
I've added a higher AD to .57 but that cause my inbound port forwarding to stop working.
ip nat inside source static tcp xxx.xxx.xxx.10 25 xxx.xxx.xxx.227 25 extendable
ip nat inside source static tcp xxx.xxx.xxx.11 25 xxx.xxx.xxx.60 25 extendable
