3845 Hardware
Jul 14th, 2009
Is it possible to put 4 NM in the 3845? I am trying to put a fax solution together using the EVM-HDA- ??? 24FXS. can I put 4 of them in a 3845 for a total of 96 fxs ports?
Is there a maximum amount of FXS ports you can add to a 3845 router?
Jonathan Schulenberg Tue, 07/14/2009 - 08:54
  • Cisco Designated VIP,
    2017 IP Telephony
A 3845 only supports two EVM modules per chassis. You'll also need to carefully plan your DSP resources to ensure you have enough.
Supporting documentation:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/isr.pdf
EVM-HD Slots: Extension Voice Module - High-Density
-The EVM-HD has the same form factor as a regular NM1
-EVM-HD offers additional voice services and higher density for in a module format.
-EVM-HD slot can take advantage of the PVDMs on the motherboard to
provide service to voice interfaces.
-The dedicated EVM slots on the 2821 and 2851 cannot accept NM/NME modules.
On the 3825, 1 EVM module is allowed in either of the 2 NME slots. On the 3845, 2 EVM modules are allowed in either of the 4 NME slots.
dvanzee@rgl.net Tue, 07/14/2009 - 08:57
What is the largest EVM port density can two support 96 fax machines? Is there some type of device which allow 100 fax ports?
Jonathan Schulenberg Tue, 07/14/2009 - 09:44
    2017 IP Telephony
The EVM supports up to 24 FXS ports so you could get up to 48 ports in a 3845 chassis.
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps3115/product_data_sheet0900aecd8016c1c6_ps5855_Products_Data_Sheet.html
For that density within a single chassis you would probably need to look at the AS5400 series chassis with an external demuxer to down-step from the T1 to individual FXS ports. I wouldn't recommend this approach though. I would just use multiple chassis.
pbruno1968 Wed, 05/05/2010 - 05:50
Is there a way to bulk add these ports into CUCM for this type of gateway (3845)?
