Transcoder Won't Register
Jul 14th, 2009
I am trying to register a Transcoder using old PVDM-12's on a 2821 running IVS_M 12.4.20(T2)
From all the docs it seems to be configured right, but not go. I have a TAC open as well, but that is just lingering.
Using CUCM 7.0.1, I have a Cisco IOS Media Termination Point Hardware device using the MAC of my router.
In the router:
voice-card 1 (this is the right slot)
dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/0
sccp
sccp ccm 10.10.10.1 priority 1
sccp ccm 10.10.10.2 priority 2
dspfarm transcoder maximum sessions 24
dspfarm
These are my errors:
vgw1#sh dspfarm
DSPFARM Configuration Information:
Admin State: UP, Oper Status: ACTIVE_IN_PROGRESS - Cause code: ADMIN_STATE_UP
Transcoding Sessions: 24(Avail: 24), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
vgw1#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.10.10.3
Switchover Method: IMMEDIATE, Switchback Method: GUARD_TIMER
Switchback Guard Timer: 1200 sec, IP Precedence: 5
Max Supported MTP sessions: 0
User Masked Codec list: None
Transcoding Oper State: DOWN - Cause Code: DSPFARM_DOWN
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED
Conferencing Oper State: DOWN - Cause Code: DSPFARM_DOWN
Call Manager: 10.10.10.1, Port Number: 2000
Priority: 1, Version: 3.1 or Higher
Call Manager: 10.10.10.2, Port Number: 2000
Priority: 2, Version: 3.1 or Higher
Any input would be appreciated.
Thanks in advance
testeven Tue, 07/14/2009 - 09:03
  • Cisco Employee,
Hi!
Have you tried to so a no sccp/sccp from the router? If you think the config is right, you can try to reload the router too.
However, you need to check too how did you add the CFB or transcoder on the CUCM Admin page. Please refer to the following link for
troubleshooting DSP registration:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080108fe6.shtml
If all the config is correct I would try to delete the transcoder from the CUCM admin page and add it again as per the following document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b04trans.html
Hope this helps! If it does, please rate :)
Teresa.
e.huntley Tue, 07/14/2009 - 09:09
Outside of restarting CUCM, I have done almost everything. The only thing that is a little shaky is that it won't let me delete the transcoder commands in the router. It says to take the DSPFARM down first, but then when you try it, it says DSPFARM is still coming up or something like that. So you can say no dspfarm, and no sccp, but it never lets you remove the settings.
testeven Tue, 07/14/2009 - 09:44
  • Cisco Employee,
Hi!
Is this the document you followed?
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html#wp1003251
Make sure you are not sharing DSPs... sometimes you are not able to shut the DSP profile if for example all the DSP resources are
being tied up on a PRI on the T1 controller. Do not share DSP resources. Make sure that each DSP profile is configured with
resouces from one media card and that you added the XCODER using the MTP on the CCM Admin page.
Teresa.
martin1.plank Tue, 07/14/2009 - 09:35
sccp ccm 10.10.10.1 identifier 1 priority 1
sccp ccm 10.10.10.2 identifier 2 priority 2
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register MTP999000000001
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 24
associate application SCCP
On the CUCM zu use MTP999000000001 for MAC-Adress of the Transcoder
Nicholas Matthews Tue, 07/14/2009 - 11:59
  • Red, 2250 points or more
This looks correct to me.
I would check 'show voice dsp group all' and 'show voice dsp detail' to make sure the DSPs are in a good state.
Next, I would start unconfiguring/reconfiguring, and restarting things.
-nick
testeven Tue, 07/14/2009 - 12:08
  • Cisco Employee,
Yeah, check DSP Hardware, probably they are bad and need replacement.
