AD HOc conference issue
Jul 14th, 2009
I can't seem to do it across the VPN.
Everyone is default g.711
Internal it works fine.
The site across the vpn can not do conferencing. So it seems that something is off. I just can't put my finger on it.
I have the CFB confgiure and have the MRG in both DP's
Jaime Valencia Tue, 07/14/2009 - 09:58
  • Cisco Employee,
  • Hall of Fame,
    2011
and exactly what happens???
no audio?
error when pressing conference 1st time?
error when trying to conference the 3 parties?
hard phones? IPC?
java
if this helps, please rate
Enable CallManager detailed trace, you should find "out of resource" or simulator message.
Conferencing resource can be configured as a profile on the Voice Gateway if you have enough DSP resource. How to find out?
Do the "Max sess ?" under the "dspfarm profile 1 conference", you only need one!!
You can also do a "sho inv" - look at PBDM's.
voice-card 0
dspfarm
dsp services dspfarm
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
Max sess ?
sccp ccm group 500
bind interface GigabitEthernet0/1.5
associate ccm 500 priority 1
associate profile 1 register GW-CNF
sccp local GigabitEthernet0/1.5
sccp ccm 10.41.5.1 identifier 500 version 4.1
sccp
Now add "Hardware conferance bridge" "GW-CNF" in CallManager and add to Resource Group for phones. Restart CallManager.
After Restart check CFB registration, and test.
