WCS - Rogue AP Un-containment
Jul 14th, 2009
I have an AP that was contained during testing. How do I un-contain it? Also, is it possible to get a listing of all Rogue AP's that have been contained?
I'm running Wireless Control System
Lucien Avramov Tue, 07/14/2009 - 13:01
you are most likely hitting bug : CSCsx16210 WCS: Incorrectly shows Rogue APs as contained
Disregard the message for now. Later release of WCS 5.2 and the following 6.0 release will have the fix.
You can acknowledge the alarm or change it's severity to be less bothered
cchughes Wed, 07/15/2009 - 11:23
No bug. I was testing containment with a spare AP. Now I cant use it because its contained.
Leo Laohoo Tue, 07/14/2009 - 18:52
Monitor > Rogues > Malicious APs
The blue drop-down menu will allow you to remove from the list.
troymaki Thu, 07/16/2009 - 07:59
Please check out the pic I attached. You have to hover your mouse over the little blue box on the right side and click 'Remove'.
cchughes Thu, 07/16/2009 - 12:57
What version is that? my screens dont look like that. I am running WCS
Trending Topics - Security & Network
