Site to Site VPN using Cisco 2651XM and ASA5505
Answered Question
Jul 14th, 2009
Hello Experts,
I have an issue setting up site to site VPN between Cisco 2651XM and ASA505.
Here's the config from both the devices.
On Cisco 2651XM
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco12345 address 205.200.8.XXX
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto map SDM_CMAP_2 1 ipsec-isakmp
description Tunnel to205.200.8.251
set peer 205.200.8.XXX
set transform-set ESP-DES-SHA
match address 102
qos pre-classify
interface Dialer1
ip nbar protocol-discovery
On ASA 5505
access-list 102 remark SDM_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list outside_6_cryptomap_1 extended permit ip 192.168.0.0 255.255.255.0 192.168.20.0 255.255.255.0
crypto map outside_map 6 match address outside_6_cryptomap_1
crypto map outside_map 6 set pfs
crypto map outside_map 6 set peer 205.200.9.xxx
crypto map outside_map 6 set transform-set ESP-DES-SHA
crypto map outside_map interface outside
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
tunnel-group 205.200.9.203 type ipsec-l2l
tunnel-group 205.200.9.203 ipsec-attributes
pre-shared-key *
Here's the output log from ASA5505
IP = 205.200.9.XXX Received encrypted packet with no matching SA, dropping
Group = 205.200.9.XXX Username = 205.200.9.XXX IP = 205.200.9.XXX Session disconnected. Session Type: IKE, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: Phase 2 Mismatch
Group = 205.200.9.XXX IP = 205.200.9.XXX Removing peer from correlator table failed, no match!
Group = 205.200.9.XXX, IP = 205.200.9.XXX, QM FSM error (P2 struct &0xd7b42260, mess id 0x84b2979c)!
Group = 205.200.9.XXX, IP = 205.200.9.XXX, All IPSec SA proposals found unacceptable!
Group = 205.200.9.XXX, IP = 205.200.9.XXX, PHASE 1 COMPLETED
Please help me out.
OJ
Correct Answer by Collin Clark about 7 years 7 months ago
Overall Rating: 3 (1 ratings)
bansal.ojasvi Tue, 07/14/2009 - 19:56
Went through the link. Tried doing what relates to my issue but no luck. Any other idea?
bansal.ojasvi Wed, 07/15/2009 - 20:30
I found out the issue. It was PFS group issue. Sh crypto map command helped me. It was showing DH1, I changed it to DH2 and the issue was resolved. Thanks for your help though.
