Post Install Newbie Question
Jul 14th, 2009
First off, CCM 6.1 with 1 pub n 1 sub, CRS 5.0(2).
Can someone confirm if the following below is correct? After reading around, my setup doesn't sound correct.
If I run C:\Program Files\Cisco\Desktop\bin\postinstall.exe on the CRS server, I am first prompted to "Identify the CAD Directory Services you want to configure", and it asks for a Primary and Secondary IP address. What address should be going in this field? The CCM server or the CRS server? Currently it is set to the CRS server, but from the documentation I look at, it seems like maybe this should be the CCM IP address.
Thanks for the help,
dhumes0524 Tue, 07/14/2009 - 11:34
Ok thank you. I am troubleshooting a problem where the reports in Cisco Agent Desktop all show up as N/A in the fields, and the Cisco Supervisor Real Time Display is completely blank. I am noticing other small things, maybe related, maybe not.
Example: In the Cisco Admin Desktop, when I attempt to "Synchronize Directory Services", I receive an error stating at least 1 error has occurred.
