CCMPWDChanger
Jul 14th, 2009
Hi Netpro
I need recovery the CCMAdmin password, when start CCMPWDChanger ask to me the Administrator Password and don't have this password but have the local adminstrator password.
Any ida how to recovery?
Jaime Valencia Tue, 07/14/2009 - 13:10
  • Cisco Employee,
  • Hall of Fame,
    2011
If you have DCD then you can open a TAC so they can decypher the registry key that holds the encrypted string. The default was ciscocisco, try it.
If you use AD, call your AD admin so he can give you that info.
java
if this helps, please rate
jmecklenburg Tue, 07/14/2009 - 13:16
Hi java
Thanks for your help, i can not create TAC case, any idea to reset this password?
billyearman Tue, 07/14/2009 - 14:58
It has been a long time since I have done this, but you can reset the PW through the registry. You will need to use the DOS application, passwordutils or something like that, that will give you the encrypted version of the password you type in. Use this encrypted password to the registry, restart the server, and you are set.
Look around for the DCDAdmin or so key in the registry, and the PasswordUtils app.
Good Luck,
Bill
poppeyrock Fri, 07/31/2009 - 03:33
did you forget the password or the CCMadmin and serviceability are not accepting your login and password?
