bcolvin Tue, 07/14/2009 - 17:27
  • Bronze, 100 points or more
As long as you don't have any VLAN's configured the AP will operate as a layer 2 device. with Vlans linked to SSID's your device will need to follow the topology defined by the VLAN/SSID subnet. IE your static IP must be in the same subnet as the VLAN theat is paired with the SSID your client is configured for.
beyond the AP you have your switch configuration to consider.
also it would be good if you pick an address outside any DHCP scopes.
Good luck
Bill
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
