Merging VPN configurations
Jul 14th, 2009
I want to merge two old PIX501's configurations onto a single ASA5505. Each has an IPSEC VPN, so this is what I thought might work. Can someone please tell me if this looks correct? The peer is a VPN router which will hand off all traffic to our ePoP.
access-list customer-1 extended permit ip 10.10.10.0 255.255.255.248 any
access-list customer-2 extended permit ip 20.20.20.0 255.255.255.248 any
crypto ipsec transform-set t-set esp-null esp-md5-hmac
crypto map cal-mic-edmz 10 match address customer-1
crypto map cal-mic-edmz 10 set peer 1.1.1.1
crypto map cal-mic-edmz 10 set transform-set t-set
crypto map cal-mic-edmz 20 match address customer-2
crypto map cal-mic-edmz 20 set peer 1.1.1.1
crypto map cal-mic-edmz 20 set transform-set t-set
crypto map cal-mic-edmz interface outside
crypto isakmp enable inside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 1
lifetime 86400
crypto isakmp policy 20
encryption des
hash md5
group 1
lifetime 86400
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
pre-shared-key *
Dave
srue Tue, 07/14/2009 - 17:37
you've got two crypto map statements for setting the peer to 1.1.1.1. this won't work.
whatever you configure here, make sure you mirror on the other side also.
if you post your two 501 configs, we can probably help more.
also, make sure you really want the keyword 'any' in your crypto acl's.
offhand, w/o seeing your 501 configs, i think this *might* be what you want:
access-list customer-1 extended permit ip 20.20.20.0 255.255.255.248 any
encryption des
hash md5
group 1
lifetime 86400
encryption des
hash md5
group 1
lifetime 86400
pre-shared-key *
prakkdangc Wed, 07/15/2009 - 05:13
Thanks for your help. Here are the two pix configs:
PIX 1 Configuration
access-list customer-1 permit ip 10.10.10.0 255.255.255.248 any
crypto ipsec transform-set null ah-sha-hmac esp-null esp-sha-hmac
crypto map vpn 20 ipsec-isakmp
crypto map vpn 20 match address customer-1
crypto map vpn 20 set peer 1.1.1.1
crypto map vpn 20 set transform-set null
crypto map vpn interface inside
isakmp enable outside
isakmp key ******** address 1.1.1.1 netmask 255.255.255.255
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 14400
PIX 2 Configuration
access-list customer-2 permit ip 20.20.20.0 255.255.255.248 any
