Attendent Console 7 on CM 7 pop screen when call rings in?
Jul 14th, 2009
I have used attendent console with other companies and do not see anyway to have the screen pop when the call rings in. It is normally a setting. It would be nice to work on excel and when it rings the console pops on live call ringing in. Also, is there anyway to keep all users up on the screen without drop down all the time? It seems you have to hit clear and select the group all the time.
Overall Rating: 5 (2 ratings)
Rob Huffman Wed, 07/15/2009 - 04:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Patty,
just to add a note to the always great tips from my friend Java (+5 points buddy!) It doesn't look like the link pasted properly, so here is the conversation I was having with Lyle;
"Hi Lyle,
Have you tried to use this method to enable / disable "Pop to Top" on AC
Note: To toggle the pop-to-top feature on and off, press Alt + P.
From this doc;
http://www.cisco.com/en/US/products/ps7282/products_user_guide_chapter09186a00806cfff5.html#wp1007405
There is also another method listed nicely by Met (with screenshot) here;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbe64a0/2#selected_message
Hope this helps!
Rob
johndgore Wed, 10/13/2010 - 10:44
We bought two monitors and that is working well.
