CCNP BSCI Official Exam Certification Guide, Fourth Edition let down
Hey all
I'm studying towards the CCNP and have booked the BSCI exam for a couple of weeks away. I've used the BSCI CBT Nuggets videos but I've also just bought the above title (well actually the cert library) and I'm really disappointed with the 'Do I already know this?' quiz.
The first chapter has 12 questions but there is no correlation to the answers for chapter 1 which has 14 answers.
Anyone know if there is an up dated PDF for this book? Given this glaring error I've found IN THE FIRST CHAPTER, I'm now really apprehensive about the quality of the rest of the book.
CC
EDIT: Note to self. Think first, type later.
Chapter 3: EIGRP Principles, page 65.
"Bandwidth is defined as 107 kbps divided by the slowest link along the path." Wrong. This should read something like: "Bandwidth is defined as 10^7 divided by the speed of the slowest link along the path."
Chapter 4: Scalable EIGRP, page 118.
The book lists 'frame-relay encapsulation' as the command to enable frame relay on a serial interface. Obviously, this is back to front.
CC
jimmysands73_2 Thu, 07/16/2009 - 10:44
Hey shipmate, both those are on the eratas page, the link I sent was the the 3rd ed, not 4th, my goof.
http://www.ciscopress.com/bookstore/product.asp?isbn=158720147X
4th Edition
Corrections for all Printings
Chapter 2, Page 41, Under paragraph heading "Reviewing IP"
Reads: 'The far right bits are the network address......".
Should read: “The left-most bits are the network address because all hosts on this network have addresses that start with this pattern. Bits to the right make up the host address because each host on a given network has a different value.
Chapter 3, Page 60, Question 1 - the correct answer is C
(http://www.cisco.com/warp/public/103/1.html#eigrp_work).
Chapter 3, page 65, First Bullet, Bandwidth:
Reads: Bandwidth - Bandwidth is defined as 107 kbps divided by the slowest link along the path.
Should read: Bandwidth is defined as 10^7 kbps divided by the slowest link along the path.
Chapter 3, Page 71, Second Paragraph
Reads: EIGRP uses both multicast and unicast addressing. Some packets are sent
Reliably using Real-Time Protocol (RTP), a Cisco proprietary protocol that oversees the communication of EIGRP packets.
Should read: IGRP uses both multicast and unicast addressing. Some packets are sent reliably using Reliable Transport Protocol (RTP), a Cisco proprietary protocol hat oversees the communication of EIGRP packets.
Chapter 4, Page 90, Question 12, b
Reads: debug ip eigrp packets
Should read: debug eigrp packets
Chapter 4, page 97, Figure 4-4
Reads:
RouterB(config)#router eigrp 100
RouterB(config)#network 10.0.0.0. 255.0.0.0
RouterB(config)#eigrp stub
Should read:
RouterB(config)#network 10.0.0.0. 255.255.255
Chapter 4, Page 101,
Reads: “EIGRP supports both clear text and MD5 authentication”
Should read: “EIGRP supports authentication using MD5 hashes. Hashed keys, sent as MD5 values . . .”
Chapter 4, page 102, Fifth Sentence:
Should read:
Finally, the key-chain is configured and the key is specified:
router(config)#key chain chain-name
router(config-keychain)#key key-id
router(config-keychain-key)#key-string key
An example configuration in AS 100
Should read:
router(config-if)#ip authentication mode eigrp 100 md5
router(config-if)#ip authentication key-chain eigrp 100 my-chain
router(config-if)#exit
router(config)#key chain my-chain
router(config-keychain)#key 1
router(config-keychain-key)#key-string secret.
Chapter 4, Page 102, Page 109 and Page 111
Reads:
router(config-if)#key chain chain-name
router(config-if)#key key-id
Should read:
Chapter 4, Page 109, in the table the first command:
Should read:
Newton #debug ip ei ?
<1-65535> Autonomous System
neighbor IP-EIGRP neighbor debugging
notifications IP-EIGRP event notifications
summary IP-EIGRP summary route processing
vrf Select a VPN Routing/Forwarding instance
Newton #debug eigrp ?
fsm EIGRP Dual Finite State Machine events/actions
neighbors EIGRP neighbors
nsf EIGRP Non-Stop Forwarding events/actions
packets EIGRP packets
transmit EIGRP transmission events
and more on the download....
