07-14-2009 11:32 PM - edited 03-18-2019 10:27 AM
Hi guys,
I have the classic disconnect problem and with all the terrible bytes on the internet have be unable to find the appropriate solution.
If i ring the PSTN line connected to the FXO port i have PLAR directing the call to 1000 my Reception phone. Im in Australia and the cptone is set to AU.
I have tried different voice class's but i am not getting anywhere. i recorded the disconnect tone from CIPC and i believe the frequency is 400, and the cadence is 380. I inserted a custom class and linked i to my voice port 1/1/0 but with no joy.....
Anyone got any ideas.....
Please advise
Solved! Go to Solution.
07-15-2009 04:02 PM
under the voice-port, add these commands -
timeouts call-disconnect 3
timeouts wait-release 3
This should drop the time to drop the call down to about 5-6 seconds after the tones are initially detected
Don't use any value lower than this as the call disconnection may become unreliable.
07-17-2009 07:37 PM
I'm not sure what they mean by a 'known problem'. Loop start operation has been around in one way or another for over a hundred years, and any specific problems would have been sorted out a long time ago. It was designed for connecting telephone handsets and the idea has always been that the people say 'goodbye' and then physically hang up towards the network. In this sense the disconnect supervision is controlled by the people on the phone call. The telephone network NEVER hangs up towards the users - it signals the far end disconnect by battery reversal or disconnect tones.
There is no reason why this should not work with disconnect tones. The next suggestion would be to get a wireshark trace of the call and then hang up the PSTN side. This will capture all the call signaling and the audio from the gateway
Groundstart is unheard of outside of North America. Telstra/Optus can supply an analogue loopstart trunk or ISDN BRI for low density connections.
07-15-2009 12:35 AM
Frequence should be 425 Hz, cadence 375 ms.
http://www.3amsystems.com/wireline/tone-search.htm?start=0&kCountry=11&kTone=10
07-15-2009 06:02 AM
As you have noted, this is a single tone of 400 hz, cadence is 380 msec on, 380 msec off.
Kind of weird - generally Telsra uses 425 hz, 350 on, 350 off. Is this connected to a 'normal' PSTN line or something else ?
Please paste your full config and we can check out exactly how you have set this up.
07-15-2009 06:33 AM
voice-port 1/1/0
supervisory custom-cptone DISCONNECT
cptone AU
connection plar 4000
voice calss custom-cptone DISCONNECT
dualtone disconnect
frequency 425
cadence 350 350
or
dualtone disconnect
frequency 400
cadence 380 380
or
dualtone disconnect
frequency 425
cadence 375 375
above is what i have tried.... but no luck
07-15-2009 06:27 AM
Try this:
voice class dualtone-detect-params 1
freq-max-power 0
voice class custom-cptone TEST
dualtone disconnect
frequency 400
cadence 380 380 380
voice-port 0/3/2
supervisory disconnect dualtone mid-call
supervisory custom-cptone TEST
supervisory dualtone-detect-params 1
hth,
nick
07-15-2009 06:37 AM
tried this, still happening...... grr
freq-max-power 0
dualtone disconnect
frequency 400
cadence 380 380 380
voice-port 1/1/0
07-15-2009 06:46 AM
Try adding
voice-port 1/1/0
timeouts wait-release 1
Forgot that one..
-nick
07-15-2009 03:39 PM
This <
You haven't mentiond IOS versions, but three is a DSP bug (CSCsq91055) that causes problems with supervisory disconnect tones in later (12.4.20T+) releases.
Try loading IOS version 12.4.20T3 , or even the very latest version of 12.4.15T (an oldie but a goodie release!)
What platform are you running this on ?
07-15-2009 03:48 PM
I configured tone based supervision for the first time, and observed it take 30 second to drop the line, although the disconnect tone is detected immediately. I have the recommended timeouts setting under voice-port.
Anybody know of a mean to shorten the 30 secs ?
07-15-2009 04:02 PM
07-15-2009 04:17 PM
This may be a version specific thing, but from what I've tested once the router decides to disconnect it will wait the designated time, and hang up. This in regards to the wait-release timer.
It sounds like from here:
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_t2.html#wp1640487
You can probably set the call-disconnect to something like 5-10 seconds, which is how long a call is connected before the router starts listening for disconnect tones. This is to prevent the router from disconnecting on something like ringtone.
I would say you should be fine setting the wait-release to 1 second, because by the time this timer is activated the router has already made the decision to disconnect the call. It's just a matter of how long of a tone you want the user to hear before it's disconnected.
-nick
07-16-2009 08:06 AM
I've seen this for a few scenarios:
This bug can do things like that: CSCsu68373
As well, are you using 'cadence continuous' by any chance? There are some intricacies with the way that works that could cause that.
-nick
07-16-2009 09:31 PM
tried it still not luck...
07-16-2009 09:32 PM
07-16-2009 09:28 PM
IOS is c3640-a3js-mz.124.25
