Gatekeeper endpoint registration not reflecting
Answered Question
Jul 15th, 2009
Hi ,
I have a gatekeeper image as below:
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9_IVS_LI-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
System image file is "flash:c3845-adventerprisek9_ivs_li-mz.124-15.T9.bin"
I have totally 12 GK Controlled ICT trunks which I have integrated with the gatekeeper.
However,I am only able to view the registrations for only 8 endpoints when I issue the command show gatekeeper endpoints.
The configurations are the same for all the GK-ICT trunks .
Please suggest.
Shams
Correct Answer by KonradStepniewski about 7 years 9 months ago
Check first gatekeeper config on missing CMs. Second check names have to be unique per cluster.
Overall Rating: 5 (1 ratings)
Correct Answer
KonradStepniewski Wed, 07/15/2009 - 01:08
  • Silver, 250 points or more
sshams007 Wed, 07/15/2009 - 01:42
Hi Konrad,
Thanks for the reply.
I have the gatekeeper configurations on the respective CUCM's and also the zone names are unique.
Any thing else you suggest that needs to be checked.
Shams
KonradStepniewski Wed, 07/15/2009 - 01:59
Next I would check if you have full connection to gatekeeper from missing clusters. Last step try to debug gatekeeper maybe you will find something there.
sshams007 Wed, 07/15/2009 - 04:19
Hi Konrad,
Just rechecked once again a couple of the trunks were having the same device name...I guess by device names u were referring to trunks earlier.
Well thanks for the same.
Shams
