Fax problems with CCME and VG224
Jul 15th, 2009
Dear all,
We have deployed a CCME on one of our subsidiaries attached to our Gatekeeper in Headquarters. Everything is working fine except one fax situation :
Internal dial-plan Headquarters --> to --> subsidiary KO (fax are not working)
Internal dial-plan subsidiary --> to --> Headquarters OK (fax are working)
Public dial-plan subsidiary --> to --> any public or international numbers OK (fax are working)
Public dial-plan Headquarters --> to --> subsidiary via international numbers OK (fax are working)
Fax are connected to a VG224 controlled with SCCP by the CCME
Here is the dial-peer configured on the Gatekeeper :
dial-peer voice 190 voip
description To Subsidiary
destination-pattern 60395....
progress_ind setup enable 3
modem passthrough nse codec g711alaw
session target ras
dtmf-relay cisco-rtp h245-signal
codec g729r8 bytes 40
fax nsf 000000
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
Here is the dial-per used on the CCME of subsidiary :
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
call start slow
sip
dial-peer voice 201 voip
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
I can give you results of debug or something else.
Thanks a lot for your help.
Florian
Nicholas Matthews Wed, 07/15/2009 - 06:07
  • Red, 2250 points or more
Hi Florian,
Try adding this to your subsidiary site:
dial-peer voice 201
fax protocol t38 fallback cisco
-nick
flabarriere Wed, 07/15/2009 - 06:58
Hi Nick,
I added the command "fax protocol t38 fallback cisco" into the CCME dial-peer but the problem is still there.
Florian
Nicholas Matthews Wed, 07/15/2009 - 07:02
Hi Florian,
You may have another problem that I can't analyze from the information given.
First check that the call is switching over in 'show call active voice brief'. You should see the codec as t38. You can also use 'show voice call summary'. If so, check for line slips 'show controllers t1' and packet loss in show call active voice brief. You would need to check the entire call flow, because so far you've only informed of GK--CME--Fax machine. No idea what is to the left of the GK.
-nick
flabarriere Wed, 07/15/2009 - 23:46
Hi Nick,
The call seems to be well established between the 2 faxes because the subsidiary fax is "ringing" when we send a document from headquarters (our fax number in HQ is 7386752).
Behind our Gatekeeper we have a CUCM cluster and Nortell, Alcatel PBX.
Please find attached the results of commands needed.
The codec used is g729, maybe this is why they can't established the connection.
Thanks for your help,
Florian
Nicholas Matthews Thu, 07/16/2009 - 05:52
Try adding this to both routers:
voice service voip
fax protocol t38 fallback none
As well, if you're on 12.4(15)T-T8, upgrade to T9 as there is a bug in those versions regarding switching over.
-nick
