How to add standby ASA with AIP-SSM
Answered Question
Jul 15th, 2009
How can I add the AIP-SSM on standby ASA in MARS. Because it does not allow to add the standby Cisco ASA. Should the Standby AIP-SSM be added independently as an IPS Device.
Correct Answer by patwill66_2 about 7 years 9 months ago
I have this same setup. Since there is only the one firewall defined in MARS, you can define two modules for it. Just edit the device, click add module and add in it manually.
Overall Rating: 5 (2 ratings)
Correct Answer
patwill66_2 Wed, 07/15/2009 - 05:55
