ACS5 Local Certificate Issue
a.moch
Hi all,
i have the evaluation ACS 5.0 version installed and have an issue with the local certificate.
I want not use a self signed certificate but a company certificate.
I did the following steps :
1. In System Administration/Local Server Certificate/Local Certificates i have generated a certificate signing request.
2. I have requested the certificate using our issueing CA.
3. In System Administration/Local Server Certificate/Local Certificates i binded the CA signed certifcate
4. i see the correct certifcate and have deleted the self-signed certificate and configured the new cert to be used for EAP and HTTPS
5. In Users and Identity Stores/Certificate Authoirities i have added the certificat for the CA
So far so good. But when i login to the WEB Gui i get still the self signed certificate presented and not the new one.
Any ideas what i have forgotten ?
Thank you
jerome
Try to install the latest cumulative patch 5.0.0.21.7 for ACS 5.0 and see if it helps to resolve your issue.
Thanks.
During uprade i get on the ssh session always this error
% Manifest file not found in the bundle
Hi... a bit late but...
You need to rename the file to ACS_5.0.0.21_ADE_OS_1.2_upgrade.tar.tar to ACS_5.0.0.21_ADE_OS_1.2_upgrade.tar.gpg
and use the CMD:
# acs patch install ACS_5.0.0.21_ADE_OS_1.2_upgrade.tar.gpg repository update
Installing ACS patch requires a restart of ACS services. Continue?  (yes/no) yes
Stopping ACS ....................... Installing patch version 5.0.0.21.ADEOS_UPGRADE
The # patch install ACS_5.0.0.21_ADE_OS_1.2_upgrade.tar.gpg update Cmd will give you the % manifest error
Bye
Thank you , update to Version 5.1 has finally fixed this issue.
