SPAN Session Limit?
Jul 15th, 2009
Running s72033-ipservicesk9_wan-mz.122-33.SXH2.bin on a 6509 Sup720.
monitor session 1 source interface Fa6/1
monitor session 1 destination interface Fa6/23 - 24
Port 24 works great! Port 23 does not. I cannot even get the port to fire up.
FastEthernet6/24 is up, line protocol is down (monitoring)
FastEthernet6/23 is down, line protocol is down (monitoring)
Is there a limit on the amount of destinations per session?
Edit: I am looking here -> http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/span.html#wp1020380
If I am reading this right, it appears as though I can have 64 destinations per session and 1 RSPAN. Does that seem correct? If so, what would cause one port to be UP/DOWN and the other to be DOWN/DOWN?
Edit: It appears as though I can't have two destinations per line card. I moved it to another line card and it fired up.
