agent (not CAD) not showing in supervisor desktop
Jul 15th, 2009
I have UCCX7.0 integrated with third party product which acts as a middleware between IPCC and Siebel. So i don't have to use Cisco Agent Desktop anymore but can use Siebel's desktop for CTI functionality (I can answer phones, log in as agent int IPCC queues, start call, transfer...)
The thing is I can't see these agents (which are logged into Siebel) in the SUpervisor desktop. If the same agent (username & extension) gets logged in CAD, it is visible in CSD.
Any idea what might be cause of this, I thought CSD doesnt mind what kind of agent desktop it is as long as it sees agent on IPCC logged in, but this obviously is not the case
Thanks for any suggestions
Pilat Goran
sebastiaanv Tue, 07/21/2009 - 22:50
Have you checked the database for the agents?
select * from t_Agent_Real_Time should give you a basic idea whether agents are registered in the database (tablename is accurate for UCCE, don't know if it's the same name on UCCX).
Back to the original poster ... there are processes that CAD talks to so that Supervisor Desktop works correctly - services like the Chat Service, Enterprise Service etc. If your Siebel desktop doesn't talk to those, the CSD may not know you have logged in.
For example ...
I know in Enterprise that you can log an agent in with CAD and see them in the CTIOS Supervisor Desktop. But the inverse does not apply - I can log in an agent with CTIOS but cannot see them in CAD Super Desktop. (I just tried it).
lohjintiam Mon, 08/09/2010 - 21:03
Just wondering which 3rd party product you're using and if it does has the full functionality of CAD.
