Using Portlets on Mgmt-Web-Portal - Login issue
Jul 15th, 2009
Hi there,
we are running a Mgmt-Web-Portal based on apache.
I integrated some portlets on a special website.
This is running very well.
The only thing is that for showing up the portles on HTML-Website a proper CW2000-Login must be performed (otherwise all IFRAME-Elements where portlets are embedded show up the login box).
Is there a possiblity to check get feedback from CW2000-System if login is already done, or must be performed prior to access the portlets?
Thanks for any feedback and ideas
Lothar
Joe Clarke Wed, 07/15/2009 - 08:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You must pre-login to LMS (or login through the various portlets before they will show you the desired information.
lo.mueller Wed, 07/15/2009 - 22:26
Hi Joe,
thanks for the update.
Aren't there any possibilities for a pre-check whether sucessful login did happen in the past and a session is still active to maybe bypass login procedure.
Maybe a certain URL returning 0 for no session active and 1 for session active.
Thanks for your update
Lothar
Joe Clarke Wed, 07/15/2009 - 22:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you have already authenticated, you will not see the login dialog. I don't really understand what you're asking for. We don't expose any such programmatic authentication check URL for user use.
