07-15-2009 06:37 AM - edited 03-11-2019 08:55 AM
I have query regarding placement of rules on fwsm using cli when inserting new acl's for getting correct sequence.
Would the original acl occupying the particular line no. be removed if i try to add/insert another acl starting with same line no(one for remark & one for actual acl)before/after(or actually in place of existing since we use that line no.) the existing acl?
eg:-(existing rules)
acl test_in line 124 remark allow to sql
acl test_in line 125 permit tcp host 192.168.100.2 host 192.168.20.5 eq 1433
acl test_in line 126 permit tcp object-group test_1 object-group test_2 object-groupTCP_4
access-list check_access line 125 extended permit tcp host users host 192.168.100.10 eq 1521
I need to insert following two line rule after rule125 ( in place of 126)
acl test_in line 126 remark allow to smb
acl test_in line 125 permit tcp host 192.168.100.100 host 192.168.20.10 eq 1433
If i insert this after rule 125 , will it push existing line 126 further ahead or remove it completely?
Also, if am correct the more specific rules should be put on top before the broad rules, correct?
Kindly help to understand.
Thanks.
Solved! Go to Solution.
07-15-2009 08:19 AM
"But for sure, doing such insertions wont cause any of the rules/remarks to be removed right."
No rules should be removed. They simply get a different line number.
Jon
07-15-2009 07:52 AM
Sunny
"If i insert this after rule 125 , will it push existing line 126 further ahead or remove it completely?"
It will push existing line 126 further ahead.
"Also, if am correct the more specific rules should be put on top before the broad rules, correct?"
Correct.
Jon
07-15-2009 08:14 AM
Thanks Jon.
07-15-2009 08:19 AM
Jon
