Traffic generators for DS3 link Stress test
Jul 15th, 2009
  • Gold, 750 points or more
Iam looking for some application (free) that generates continuous traffic on a DS3 link. Wanted to test a new DS3 link with full capacity and move it production, once completed. Any suggestions on the application to use..?
TIA
MS
Overall Rating: 4.3 (3 ratings)
Giuseppe Larosa Wed, 07/15/2009 - 07:40
  • Hall of Fame,
    Founding Member
Hello Mehboob,
you can try to use netperf it requires to be installed on two linux or freebsd boxes one on site A and one on site B
see
http://www.netperf.org/netperf/NetperfPage.html
I've used it some years ago you can use UDP streams or TCP streams
(TCP results can be lower)
Hope to help
Giuseppe
mvsheik123 Wed, 07/15/2009 - 07:43
Great..thank you. Anything on windows hosts..?
MS
cisco24x7 Wed, 07/15/2009 - 08:48
  • Silver, 250 points or more
I just tested this a few days ago. Iperf will work on both Windows and Unix platform. This is really a good tool.
If you want to saturate the DS-3 link, it is probably best to use UDP instead of TCP:
On the server:
iperf -u -s
On the client:
iperf -u -c 192.168.1.218 -b 45M -t 86400
[[email protected]-fwlog]# iperf -u -c 192.168.1.218 -b 45M -t 86400
Client connecting to 192.168.1.218, UDP port 5001
Sending 1470 byte datagrams
UDP buffer size: 256 KByte (default)
[ 3] local 192.168.1.245 port 44737 connected with 192.168.1.218 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 53.7 MBytes 45.1 Mbits/sec
[ 3] Server Report:
[ 3] 0.0-10.0 sec 53.7 MBytes 45.1 Mbits/sec 0.019 ms 0/38316 (0%)
[ 3] Sent 38316 datagrams
That will tell you if your DS-3 is fully utilized.
Easy right?
nick.mueller Wed, 07/15/2009 - 17:11
Here is a graphical front end to iPerf written in Java. You may need to rework the shell script to launch it if you are running Vista x64 as it uses 32-bit java and the path is changed to Program Files (x86).
http://code.google.com/p/xjperf/
mvsheik123 Thu, 07/16/2009 - 09:34
Thanks Nick. I am planning to use XP PC/laptop (one at each end) for the test.
MS
