NTP run and installed
Jul 15th, 2009
i had instaled ntp on catalyst 4500 r switch no w i check command on show clock detail
there i got run with mtp .
now i had system with windows 2003 server onthat iawant to insttaled how i do this task?
douhanm Sat, 07/18/2009 - 11:22
not really sure what the actual question is but here is a stab at answering a few possible ones
1. on the 4500 you can check NTP status with show ntp asso or show ntp stat
2. on win 2003 you need to install a NTP client SW in order to get it to synch with the NTP source
