toggling several times between 2 call before doing a transfer
Answered Question
Hi all,
Here is the description of the scenario :
A calls B in order to be transferred to C.,so, B calls C. At this moment we have the call A-B on hold and B-C active. B , for some reason, put C on hold and come back to A (to verify some thing). At this point, B decided to make the transfer, by doing a direct transfer for example. However, A see that his phone shows that the call is "fom C" whereas actually he has dialed first.
How could we overcome this little prob.
thanks.
Correct Answer by CHRIS CHARLEBOIS about 7 years 9 months ago
Direct Transfer is such a pain to use and to train people on using we don't even cover it in our end-user training and we remove the DirTrfr softkey from the template. The only place it makes any kind of sense is in a receptionist role, and they use the Attendant Console to do the same thing. I would approach it from an end-user training perspective. If B knew that A wanted to talk to C, B should have initiated the call to C as a transfer in the first place. If not, B should tell C that B will the send the call from A immediately, disconnect, then cold-transfer A to C.
Overall Rating: 5 (2 ratings)
Correct Answer
CHRIS CHARLEBOIS Wed, 07/15/2009 - 10:04
  • Silver, 250 points or more
Rob Huffman Fri, 07/17/2009 - 04:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chris,
I like your thinking here! Sometimes the old "KISS" principle really comes into play. +5 points for this excellent advice for Ramzi.
Cheers!
Rob
