AIP-SSM outside inside dmz
Jul 15th, 2009
hi
I'm reviewing the situation next three traffic zones outside, inside, DMZ,
service-policy xxxx-policy interface outside
service-policy xxxx-policy interface inside
service-policy xxxx-policy interface dmz_stgo
and I need to lower the level of examination but only in one area, which is the area inside,
such outside high-DMZ
DMZ-outside high
inside low-DMZ
rhermes Wed, 07/15/2009 - 14:14
  • Gold, 750 points or more
Please give us some additional detail on whatyou mean by "lower the level of examination" on one of your interfaces. Did you want to apply a subset of the signatures? (then you'd go down the virtual sensor path) Or, did you want to filter the IP addresses/port reaching the sensor on that interface? (then you'd adjust the class-map ACL)
alexispino Wed, 07/15/2009 - 14:48
ok I have a situation where some companies want to change but the signatures are applied only to traffic from inside to DMZ
and the class-map
access-list xxxx permit ip any any
