UCCX simultaneous ringing
Jul 15th, 2009
Hi all,
Is it possible to have all the agent phones( in a specific resource group) ringing simultaneously when a call comes in a CSQ.
I couldn't find any such option in resource group configuration.
thanks
Simranjeet
Overall Rating: 4.5 (2 ratings)
Jonathan Schulenberg Thu, 07/16/2009 - 05:03
Nope. The call will be offered to one resource [agent] at a time based on the logic you have set. The length of time the call is offered to the agent is controlled by the timeout parameter on the Select Resource step.
