Load balancing question
Jul 15th, 2009
I have 2 separate links going to the same site. Each link has its own router from the local Telecom hanging off each circuit. Can I use a 2821 to load balance over these 2 links with the telecom routers attached?
chinkevi_2 Wed, 07/15/2009 - 21:47
hi, we need more pictures on the setup.
do you mean there are 2 telecom routers going to a remote site, and you want a 2821 router to load balance to each telecom routers in order to reach remote site?
Rui Carlos Antunes Mon, 07/20/2009 - 04:10
You should use BGP for that, so you will need an IOS with a Feature Set that supports it.
Also, Cisco 2821 can handle about 80Mbps of traffic (CEF-switched). If the trafic on your network is higher than that, you need a higher-end router.
