Archive management failing on 6509E
Jul 16th, 2009
Hi, my attempts to backup some 6509Es with RME are failing. All credentials are correct. I've looked at the dcmaservice.log and this has an entry showing:
..Unknown authentication method:Keyboard Interactive.
When manually SSH'ing to the device the ssh client does show "using keyboard-interactive authentication" after entering the username. Non of the other non 6509E devices display this and are consequently backing up fine. Anyone any ideas?
CWLMS 3.1 on Windows.
Thanks in advance.
Joe Clarke Thu, 07/16/2009 - 06:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This almost certainly points to wrong credentials in DCR for this switch. What is the error you see in RME when trying to archive the config? What version of code is the switch running?
paulhowlett_2 Thu, 07/16/2009 - 06:40
Hi, the error is:
CM0151:Error occurred while fetching config from device:send()called with SSH packet in this buffer.
IOS 12.2(33)SXI1
I've run a credential check for SSH and this comes back OK.
Joe Clarke Thu, 07/16/2009 - 06:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't see this error in the code. I suggest you open a TAC service request so more debugging can be done.
