Filtering calls ( internal and external) to a specific DN
Answered Question
Hi all,
How could we filter numbers (internal and external) that could reach a specific internal DN ( a VIP :-) ) ?
best regards,
Correct Answer by Jaime Valencia about 7 years 10 months ago
No, IPMA is the only way to configure the inclusive or exclusive filters to do what you want.
Otherwise it goes to CSS/partitions config.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Tim Smith Thu, 07/16/2009 - 05:36
  • Silver, 250 points or more
You should look into the IPMA feature. It is in the CUCM documentation.
Cheers,
Tim
Correct Answer
Jaime Valencia Thu, 07/16/2009 - 08:14
  • Cisco Employee,
  • Hall of Fame,
    2011
java
