ACS 1113 Very slow through IE8
Jul 16th, 2009
Since I upgraded to IE 8, trying to admin the ACS GUI is very frustrating. It acts as though I am on a dialup connection. Could it be IE 8, or the version of Java running? What is the recommended Java version to use with IE8 and 4.2 ACS?
Jagdeep Gambhir Thu, 07/16/2009 - 07:47
Many user's are facing this issue. It is the Java that is causing a problem. Latest Java ver did not help.
Wait for next java release
~JG
Lucien Avramov Thu, 07/16/2009 - 14:01
Java Run-time Environment (JRE)
•Sun JRE 1.4.2_04
•Sun JRE 1.4.2_16
•Sun JRE 5.0 Update 13
•Sun JRE 6.0 Update 3
As per the install guide:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/installation/guide/windows/install.html
With a downgrade of java and IE8, it seems to work better.
Try to avoid IE8 as possible, it was not tested with ACS yet.
tahequivoice Mon, 07/20/2009 - 09:54
Thankfully Firefox appears to be working OK with the ACS. I need to give my workstation a once over as the Office products are screwed up as well as IE. Way to go Microsoft!
