ACE-round robin with ssl-id sticky issues
Jul 16th, 2009
Issue - roundrobin algorithm not working
Real servers - 4
algorithm - round robin
sticky method - ssl-id based sticky
Software
loader: Version 12.2[120]
system: Version A2(1.0a) [build 3.0(0)A2(1.0a) adbuild_04:14:49-2008/04/18
_/auto/adbu-rel3/rel_a2_1_throttle/REL_3_0_0_A2_1_0A]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_1_0a.bin
installed license: ACE-VIRT-020
If you have encountered this issue before and solved it or if you know the solution please share.
config
policy-map type loadbalance generic first-match ABC_mytest.com_443
class SSLID_32_443
sticky-serverfarm SSL_32_mytest.com_443
class-map type generic match-any SSLID_32_443
2 match layer4-payload regex "\x16\x03[\x00\x01]..[\x01\x02].{37}\x20.*"
3 match layer4-payload regex "\x80\x4c.*"
sticky layer4-payload SSL_32_mytest.com_443
timeout 60
serverfarm ABC_mytest.com_443
response sticky
layer4-payload offset 43 length 32 begin-pattern "\x20"
serverfarm host ABC_mytest.com_443
probe Standard_TCP_443
rserver webserver1
inservice
rserver webserver2
inservice
rserver webserver3
inservice
rserver webserver4
inservice
Thanks.
