CSS11500: Communication outside a circuit VLAN
Jul 16th, 2009
I have a circuit VLAN152 which has a bunch of servers behind it. For some reason the servers lost the ability to communicating outside this VLAN. Servers had the the correct Gateway: 10.10.146.195.
I resolved the problem by completly removing circuit VLAN152 from the CSS config and re-creating it. All communication started working properly once it was re-created.
circuit VLAN152
description "AM/LDAP Subnet"
ip address 10.10.146.193 255.255.255.224
ip virtual-router 200 priority 110 preempt
ip redundant-interface 200 10.10.146.195
ip critical-service 200 Monitor_v16_v152
CSS11503# sho ip routes
prefix/length next hop if type proto age metric
0.0.0.0/0 10.10.16.1 1023 remote static 3370002 0
10.10.1.0/24 10.10.1.27 1024 local local 3370039 0
10.10.3.0/24 10.10.3.5 1021 local local 3370039 0
10.10.16.0/20 10.10.16.39 1023 local local 3370039 0
10.10.65.0/24 10.10.65.14 1022 local local 3370040 0
10.10.146.0/27 10.10.146.2 1019 local local 3370039 0
10.10.146.64/27 10.10.146.66 1020 local local 3370039 0
10.10.146.128/26 10.10.146.130 1018 local local 3370039 0
10.10.146.192/27 10.10.146.193 1017 local local 1709452 0
CSS11503# sh ver
Version: sg0810106 (08.10.1.06)
Flash (Locked): 08.10.1.06
Flash (Operational): 08.10.1.06
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Secure Management
Has anyone seen this type of behavior before and what's the root cause ?
Thank you in advance!
Manjit
